10 mile final....
914Driver
Re: 10 mile final....
Postby 914Driver » Fri May 04, 2018 9:09 am
Thanks, exactly what I thought. I won't tell you about the helo pilot who used profanity on the radio, hopped in his Lamborghini and raced out to the flight line to grab an instructor by the throat. Assault on an old guy is only a misdemeanor, we let his peers eat him up.
Postby MrMorden » Fri May 04, 2018 9:29 am
drseti wrote:Gliders have right-of-way over power planes. All.The.Time.
Some of the glider pilots around here use this rule to bully us powered aircraft drivers and do whatever they please. I understand the need for the rule, but I'd prefer folks use it responsibly and not as a blanket excuse for rudeness...
Postby 3Dreaming » Fri May 04, 2018 9:53 am
Andy, I am not sure how they do things down there, but I have been hanging around at our local glider club the past year it is certainly not the case around here. I have been flying a glider some, and I can tell you there are times that you can get caught when the lift goes away and not be able to fly a "normal" traffic pattern.
Postby MrMorden » Fri May 04, 2018 10:28 am
3Dreaming wrote:Andy, I am not sure how they do things down there, but I have been hanging around at our local glider club the past year it is certainly not the case around here. I have been flying a glider some, and I can tell you there are times that you can get caught when the lift goes away and not be able to fly a "normal" traffic pattern.
Oh sure, I don't have a problem with a glider saying he has to expedite a landing and land in front of me or make me change plans. That's understandable. But when the gliders won't let me land runway 3 because they are landing runway 21 (in spite of wind), and then I switch to 21 and they tell me I can't land there either because they are about to take off from 3 and I need to circle a bit, it's pretty frustrating. I mean come on guys, you can't have the ENTIRE airport for your glider ops. No apologies or attempt to expedite, just "we're taking off on one end and landing at the other, we're gliders and you have to get out of the way".
Postby 3Dreaming » Fri May 04, 2018 11:46 am
The regulations are clear that the landing glider has the right of way. It is also clear that you should have the right of way over aircraft, (the glider), sitting on the surface. Maybe a gentle reminder that their sitting on the runway causing you to take evasive action for landing could possibly be considered a runway incursion.
Postby drseti » Fri May 04, 2018 12:12 pm
Here are the right-of-way rules, as I recall them:
An aircraft declaring an emergency always has right-of-way over everybody else.
In flight, the least maneuverable category and class has right-of-way.
When multiple aircraft are landing, that applies. If equally maneuverable, the aircraft at the lower altitude has right-of-way.
Aircraft taking off must always yield to landing aircraft, with the exception of seaplanes, where the aircraft taking off has priority (because you can't stans on the brakes and sit at the hold-short line when you're on floats).
914Driver
Postby 914Driver » Sun May 06, 2018 7:10 am
Thankfully I've never witnessed the rudeness cited by 3Dreaming, hopefully it was isolated PMS and not a mindset.
I still disagree with the straight in landings ....
Dan
Postby 3Dreaming » Sun May 06, 2018 9:04 am
914Driver wrote:Thankfully I've never witnessed the rudeness cited by 3Dreaming, hopefully it was isolated PMS and not a mindset.
Dan
I didn't cite any rudeness, in fact just the opposite.
914Driver
Postby 914Driver » Mon May 07, 2018 6:30 am
Agreed, apologies for the misquote.
Izzy
Postby Izzy » Thu May 10, 2018 3:53 pm
I was taught and always fly a pattern as indicated (R or L) using the 45º entry point on downwind. Not to long ago, while flying at a busy NTA, there was an emergency declared by a pilot and WE all cleared the area giving room for the pilot to set their plane down safely.
I have the following link in my resource file:
https://www.faa.gov/documentLibrary/med ... 90-66B.pdf
Cheers!
Izzy
Return to “Safety Corner”
