Momentary Lapses, Gumption Traps and Fast Eddie (long)
(I posted this to the ctflier forum yesterday, but I realize not everyone here frequents that site. For those of you who do, I apologize for the duplication)
I think we can all point to times we’ve had momentary lapses of attention. Hopefully, most times the consequences are minor or just irritating. But think of some of the recent lapses discussed here and elsewhere:
A professional Asiana airline crew with a momentary lapse involving auto throttles crashing short of the runway.
Two professional crews with a momentary lapse landing at the wrong airports.
Two CT’s with low fuel emergencies, one which crashed and one which came perilously close to doing so.
At a Cirrus “Critical Decision Making” seminar, they played a video showing a momentary lapse of an amphibious seaplane pilot, putting the gear down instead of up for a water landing. With results almost more tragic than one can imagine.
And finally, the ValueJet Everglades crash was caused by mislabeled oxygen canister - someone obviously had a momentary lapse somewhere - and a LOT of people died.
I had a major one in the past, involving an unlatched canopy on my Sky Arrow, which could have had dire consequences - but fortunately didn’t.
The longer most of us fly, the longer the list of momentary lapses grows. There may exist a pilot who never, ever makes mistakes, but I have not yet found him or her. Checklists help, as do copilots or mechanics to check your work.
How does this involve me right now? I had a momentary lapse which I thought I’d chronicle here as a possible warning for others.
Last Wednesday, I made a trip to my (very cold) hangar with two new purchases in hand - a newly purchased Whelen LED landing light and a new Aerovoltz Lithium Iron battery. I was really looking forward to making two minor improvements to my Sky Arrow. Especially the battery, which would buy me about 12 or 13 extra pounds of valuable useful load.
I had fun with the LED install, even taking time to set up a rig to compare the new lamp and the old. Job well done, if I do say so myself.
Then it was time to see if the Aerovoltz would fit conveniently in the existing battery bracket. Good news - it was not as wide as I thought and wedged right in there, though I would have to come up with a spacer arrangement before testing it in flight.
I also made note that the terminals were reversed, something to be aware of but not a problem since both battery cables seemed to have plenty of reach. Hooked up the cables, made sure both terminals were protected, snugged everything down and turned on the BATT switch. New landing light performed as promised, and everything seemed fine.
But looking at the install more critically, I was not completely pleased with the “run” of the positive cable. It was about 1” away from the allen bolt that controls my nosegear friction. It looked easy enough to run both cables on the other side of a wiring bundle to give more clearance, and seemed the prudent thing to do. So I unhooked both cables, rerouted them, attached them and tywrapped them in their new location. Went around and turned on the BATT switch to confirm the connections and…
…instead of everything coming to life, there was a quick hissing/pop sound. As quickly as I could I turned the switch off, and noticed a slight burning electrical smell. You can’t imagine the sinking feeling I had when I looked at the battery and discovered I had hooked up the cables in their old orientation. Which, unfortunately, fed reverse current into my electrical system when I threw the switch.
That feeling was a combination of disgust and anger and disappointment in myself. I felt in my gut. I am NOT the kind of person to hook a battery up backwards. I check always check polarity and then check it again. If someone else was relating this account, I’d roll my eyes and think that that could never happen to me - I’m too careful.
So, what happened? The first hookup was done with utmost caution for anything that could go wrong - including the new orientation of the terminals, routing the wires, protecting the terminals, all of that. On the second, I guess I was just coasting, on “automatic” as it were, and when it came time to hook up the terminals I did them just as I always had. Looked perfectly normal. Unfortunately, in this case it was backwards.
Anyway, here’s the final install, before spacers and after the cables were reoriented properly:
You can see the allen bolt I was getting clearance from by going outside of the existing wire bundle.
It reminded be just a little bit of a very mild version of what Robert Pirsig, in “Zen and the Art of Motorcycle Maintenance” called a “Gumption Trap”.
What’s a Gumption Trap? It’s best illustrated by a fictional, but all too possible scenario:
Imagine you’re setting the blade angles as you reinstall a Warp Drive propeller. You install the prop bolts lightly, and back off on the clamp bolts a little. You use your tape measure to ensure each blade is in exactly the same position, and use your protractor device to set each blade just so. You tighten everything up incrementally with your torque wrench in stages, then do a textbook job of safety wiring the prop bolts. Finally, you reinstall the spinner with just the right dab of blue Loctite on each screw, and stand back and gaze upon a job well done.
As you’re putting your tools away, you stumble upon the 1/8” spacer that’s required between the prop and the engine on your installation. Drat! Now its all got to come completely apart and be redone.
This is where the Gumption Trap can rear its ugly head. Typically you’ll be somewhat annoyed and kind of rush into redoing something you’ve JUST done - and rarely with the patience and care you took the first time. The cure is to step away - go home, relax, have a drink, whatever. But regardless, come back to the project when you’re fresh, not aggravated. Don’t fall into the Gumption Trap!
My case was not exactly like that, since I was in no way annoyed at having to reroute the wires - I was kind of proud of myself for having the foresight to envision a possible problem and deal with it, getting it “just so”. But there’s no doubt I wasn’t really giving it 100% of my attention. The dreaded “momentary lapse” mentioned above.
As an aside, a fellow EAA member and friend was helping me with some stuff you’ll find in my first epilogue, to follow. I explained how this was embarrassing as I was NOT the kind of person to pull such a doofus mistake. He said he felt exactly the same way about ever running out of fuel - he was NOT the kind of person to ever pull a bonehead stunt like that. Until he did, and had to ditch with his wife in the Atlantic Ocean off the Florida coast. Made me feel a little better, I suppose.
But not much. :(
To be continued…
Re: Momentary Lapses, Gumption Traps and Fast Eddie (long)
Epilogue #1...
Well, after the sick feeling I got from hooking the battery up backwards, there was nothing to do other than hook it up the right way and assess the damage.
First thing that I noticed was that the flap breaker had popped - it was the only one that had. Popped it back in and the flaps worked - whew!
Went through everything electric I could think of - strobes, nav lights, trim, panel lights, fuel pump, Dynon, 496, radio, etc., and everything seemed to be working.
Except…
The Garmin GTX327 transponder would not come on. I pulled it with my friend and we found a 5A fuse blown on the circuit board. Unfortunately soldered on. Called Garmin, they said it was a field serviceable part ($1) if that was all it was. Called Horizon Avionics in Knoxville and they said they’d be happy to look at it. They asked about the encoder, which had not crossed my mind, and suggested pulling that and bringing it in at the same time. I’m planning to do so one day next week. If the transponder does have to go back to Garmin, it’s something like a $575 flat rate repair.
I initially could not hear audio from my radio. Noticed I could when I switched the intercom off (neither squelch nor volume had any effect). It’s a Sigtronics and I sent it back to them yesterday. Repair cost is capped at $69 plus return shipping if the unit can be saved, which they thought it could. If it’s toast (and it did have a burned electric smell) then a new one is around $279.
I’m really hoping that’s all that was damaged. Things with switches that were switched off should have been protected, and I’m pretty sure I only turned on the BATT side so the Alternator and hopefully the voltage regulator should be OK. I hope.
Oh well, it is what it is and compared to some of the tragedies that I listed in the initial post, this will over time fade into insignificance and go down as a learning experience. It’s only money.
More as it develops…
Post by Merlinspop »
Sorry this happened, but it's better to have had a bonehead moment on the ground than aloft.
Excellent time to knock out that seatbelt upgrade!
Merlinspop wrote:Sorry this happened, but it's better to have had a bonehead moment on the ground than aloft.
Thanks.
I'm leaning to just installing two lap belts at about $60 each, probably in March with my annual.
Not as elegant as the $1,200+ solution from Magnaghi, but that's a huge premium on elegance!
FastEddieB wrote: Thanks.
Oh, yeah! Just practice egress with the extra buckle.
Merlinspop wrote:
FastEddieB wrote: Oh, yeah! Just practice egress with the extra buckle.
Will do. To save $1,000 or so I think we can practice that a bit!
Epilogue #2:
1) Got a message from Sigtronics. I was prepared for the worst, but when I called back they said the damage was a little too extensive to fit into the usual $69 maximum repair. Good news is they can still do it for $80 to $90, and say it will be as good as new. Whew!
2) The encoder was ridiculously easy to pull, and yesterday we dropped off the transponder and encoder at TACAir in Knoxville for Horizon Avionics to pick up tomorrow morning. I'll report back the findings.
This too shall pass...
Yesterday I took my Brother PTouch label maker to the airport, and added two wrap-around labels to my battery cables. The POS one is red, and the NEG one black. Battery terminals similarly labeled. Hope this will help to prevent a bonehead moment. Thanks, Eddie, for letting me learn from your mistake.
drseti wrote:Yesterday I took my Brother PTouch label maker to the airport, and added two wrap-around labels to my battery cables. The POS one is red, and the NEG one black. Battery terminals similarly labeled. Hope this will help to prevent a bonehead moment. Thanks, Eddie, for letting me learn from your mistake.
Great idea Paul.
When I get my airplane home, that's one of the first things I will make happen.
Great idea Paul.
I did that on my camper. I don't use it a ton, so I have to pull the battery to keep it from getting overly discharged. I'm always super paranoid about hooking it back up backwards.
Great ideas.
Of course, in my case I did install a bright red cap on the positive wire, and a smaller black one on the ground.
The weak link in the chain is the new battery - just small and easy-to-miss "+" and "-" embossed into the case.
NOT AN EXCUSE! Doofus is as doofus does. But just pointing out if one's mind is drifting, even obvious cues may be overlooked. I would not have thought it possible in my case, but there you have it!
It's even worse with my antique MG battery. Positive ground! :(
The Professor has seen this:
http://www.youtube.com/watch?v=v3iPrBrGSJM
Without any spoilers, see if it has any relevance at all to this thread.
Neat trick, regardless!
rk911
Post by rk911 »
FastEddieB wrote:The Professor has seen this:
http://youtu.be/hsmwJcnIznQ
'73,
rich, n9dko
My high school chess club kicked me out once they found out about my checkered past
_________________________________
Eddie, I think you posted the wrong URL.
