or
I am landing and think that I have bled off enough speed so I pull back only to begin to climb again. Flight Design has no stall horn.
Cue carnival huxter: "
Do you have these problems pilots!
For just .99 you can get an app that shows you in BIG LETTERS what your airspeed is on heads up display.
It shows you on your ipad in BIG NUMBERS and in reverse so you can put your iPad onto your glare shield in front of you and then keep your eyes on the runway while seeing the ghostly image of your air speed increasing or bleeding off for landing!
Just .99 (should be $19.99 as all crap on t.v. is priced)"
I'm going do do some runs around the patch to see if it works.
