Dead reckoning in checkride?
Doss79
Post by Doss79 »
Do the examiners often test you in dead reckoning knowledge during the checkride? That's my weakness :oops: I'm bad at math and easily forget how to use the E6B!
cdillis
Location: Erie Municipal Airport; Erie Colorado; Centennial Airport, Denver, CO
Post by cdillis »
You can absolutely expect to be tested on dead reckoning and pilotage. These are the only types of navigation a sport pilot is required to know, so you can bet the examiner will want to see that you know how to find your way around.
As for your E6B problems... just practice, practice, practice. Run through a bunch of problems while on the ground, either by yourself or with your instructor. Get good with the E6B in the comfort of your own living room before trying to work with it in the air.
Good luck on your checkride!
Christopher Dillis
President, Skyraider Aviation, Inc
395 Airport Drive
Erie, CO 80516
Centennial Airport
13376 E. Control Tower Road
Englewood, CO 80112
http://www.skyraideraviation.com
303-926-0114
Paul Hamilton
Post by Paul Hamilton »
Another way around the rotating slide rule E6-B is the electronic version CX2 at http://www.ap-stores.com/p-70-cx-2-path ... puter.aspx
Doss79
Post by Doss79 »
Thanks Paul, but I've practically barred myself from spending anymore on tools and gadgets at the moment...
I'm fine with the E6B, it's just a hassle using it in flight when flying in the backseat of the Cub with the wind.
Paul Hamilton
I personally test the use of the E6B on the ground and not in flight with open cockpits.
