Southern Appalachian Fly-In (take 2)
Fly-Ins are excuses for pilots to go somewhere and eat. Airplanes. Food. What else could you ask for? Know of an upcoming fly-in? A great $100 hamburger? Don't keep it a secret. Share it here!
Re: Southern Appalachian Fly-In (take 2)
I long ago discovered that the mountains have their own weather.
And that can cut both ways - sometimes its noticeably worse than the flatter terrain to the south and north, sometimes noticeably better.
And today was the latter - there was nary a hint of a gust all day, with maybe 5kt or 6kt winds at the most - a perfect day for flying - once you got here!
As always, discretion is the better part of valor!
FlyingForFun
Post by FlyingForFun »
Delete
Flocker
Post by Flocker »
FastEddieB wrote:And the very detail oriented might notice something I forgot to do!
I watched it twice and could not spot it. What did you forget?
Aviation Real Estate Broker
Hint: look up the field elevation at 1A3.
Flocker
Post by Flocker »
FastEddieB wrote:Hint: look up the field elevation at 1A3.
1,789'
Watched it again & it still evades me. Give us 1 more hint...
OK...
...can you see what my altimeter reads on the ground?
Flocker
Post by Flocker »
FastEddieB wrote:OK...
Got it now! Thanks
Yeah, I forgot to set my altimeter and did the entire flight with it indicating about 200' high.
Did not notice it until taxiing in.
First time in a long time I've forgotten that. Probably earned itself a place on my checklist!
FlyingForFun...
You have me curious...
...is there a reason you went back and deleted your posts?
FlyingForFun
Delete
FastEddieB wrote:First time in a long time I've forgotten that. Probably earned itself a place on my checklist!
And by 'fessing up, you probably saved somebody else from making the same mistake. Good job of teaching by counter-example, Eddie!
It doesn't replace checking the altimeter but Dynon's (D-100 and, presumably, Skyview) have a setting where the altimeter remembers the altitude when it was turned off then resets the barometric pressure to the last known altitude when powered back on.
