Rotax Enhanced Annual and Service Class May 4th & 5th, 2024
Time to sign up for the May 4th & 5th, 2024 Enhanced Rotax Service class.
Hi All,
It's getting closer to class time and slots are closing up. If you own a Rotax engine you should take a Rotax service class that will teach you all the everyday maintenance , but with our class we not only cover that, but we use a Rotax inspection checklist and go down that item by item. Plus we get into hoses, hose change, clamps and how to adjust your prop the proper way. We delve deep into carb sync and what the gauges are telling you and we do real time carb syncs. You'll learn how to diagnose with gauges. We work on a live aircraft / engine.
What's really unique about this class is we keep the class size small at 10 students because you all will be turning all the wrenches and screwdrivers for the annual checklist.
Because of he way we teach, work on the engine, do an annual on an engine and have all the students do the work this will answer all your Rotax questions and since you are doing all the work you will remember more from this class.
There is no way you can attend this class and not learn things.
Tucson, AZ
520-349-7056
