This is a two day class.
Dates: May 4th & 5th, 2024 Saturday & Sunday (0800 hrs. – 1700 hrs) Cost: $450
Do to the hands on work a maximum class size is 10-12. Pre-registration is needed because classes are usually full.
Phone: 520-349-7056 or Email: [email protected]
This is an improved service level class that will raise and improve the 100 hour and annual inspection understanding. It will guide people to perform at a higher level of education and knowledge base whether you are a private owner or a mechanic. After discussions and feedback with the students that have taken this enhanced Service class with mostly hands on instruction they feel like they are capable of performing at a higher level with inspections, performing simple service work and documenting in the logbook over some other service classes. This class will have a couple hours of classroom each day, but the majority of each day is all hands on work with a functioning Rotax 912ULS and a 912iS engine and targeting the 100 hour / annual inspection and general service work. We will perform an actual annual inspection on a functional aircraft and every student will be supplied with an inspection checklist. We will demonstrate and perform other service functions. While working you will be able to ask real time questions and take notes to help your understanding of the work when you return home. This will empower owners and mechanics to perform better 100 hour and annual inspections, better DOCUMENTATION, and service-based maintenance on the 912 engines. This class will expand on the already successful Rotax Service class by incorporating more hands on time, but more importantly it will expand on better logbook documentation and will focus on a more detailed and proper inspection process while performing service-level work on the 912 UL, ULS & iS class engine and the 914 engine. This enhanced class will help reduce maintenance induced engine problems and simple time consuming inquiries to the Rotax distributors’ and owners’ maintenance based questions.
Classroom instruction: each day is 3-4 hours of classroom with engine part props
1. Registering engines
3. Proper use of hose clamps, clamping techniques and the tools. Types of clamps and demo each including Oetiker, Band-It, fuel injection clamps and the constant compression spring clamps.
19. Gearbox removal and installation. We will disassemble a gearbox just to allow students to see its interior parts operation (no maintenance, just prep for shipping to a distributor)
22. Fuel pump replacement
28. Proper prop pitch setup demonstration. This seems to be a big one for many people. Many owners and A&P’s don’t know how to do this and it’s important for the engine.
Tucson, AZ Rotax Enhanced Service Class Details
May 4th & 5th, 2024
The class is May 4th & 5th, 2024 (Saturday & Sunday). The class will start promptly at 0800 each day. There will be classroom presentation in the Ryan Airfield conference room each day in the morning and work in the hangar each day after the class presentation. There will be a lunch break each day at approximately 1130 hours.
Please bring a laptop or tablet device in case you need to find Rotax information and manuals on line. There is Wi-Fi in the classroom.
The class is being held at Ryan Airfield (KRYN) in Tucson, AZ. (9698 W Ajo Hwy). This is west of Tucson proper and city limits and approximately 15 minute drive from the Tucson Airport (TIA). If you fly in your own aircraft parking is right up at the back door of the conference room. Rental cars are available at Tucson Airport or Enterprise car rental on Valencia road and Uber can pick you up at Ryan if you need a car from there.
Directions to Ryan Airfield are as follows and can be reached by either Ajo Hwy or Valencia Rd. They both run right in front of Ryan Airport. The conference room is up front at the airport on Ajo Hwy. It is the only building out on Ajo Hwy and the only parking out on Ajo Hwy.
If you are staying in Tucson central or out by Interstate 10 then take I-10 to I-19 south. Immediately exit west onto Ajo Hwy. Follow this road 12 miles out to Ryan Airfield.
If you are staying in a hotel out by Tucson Airport off Valencia Rd. Just head west on Valencia until it dead ends right at Ryan Airfield on Ajo Hwy. or for a unique experience Casino Del Sol at 5655 W Valencia Rd. just 5 minutes down the road from Ryan Airfield. This is a large Native-American Casino.
There is a restaurant at Ryan field. There a two other restaurants in the area. We can share cars.
For questions call Roger Lee in Tucson, AZ at 520-349-7056
Rotax Enhanced Annual and Service Class May 4th & 5th, 2024
- Rotax class for 2024.docx
- (26.68 KiB) Downloaded 139 times
- Rotax class directions 2024.docx
- (13.61 KiB) Downloaded 143 times
Re: Rotax Enhanced Annual and Service Class May 4th & 5th, 2024
Hi All,
It's getting closer to class time and slots are closing up. If you own a Rotax engine you should take a Rotax service class that will teach you all the everyday maintenance , but with our class we not only cover that, but we use a Rotax inspection checklist and go down that item by item. Plus we get into hoses, hose change, clamps and how to adjust your prop the proper way. We delve deep into carb sync and what the gauges are telling you and we do real time carb syncs. You'll learn how to diagnose with gauges. We work on a live aircraft / engine.
What's really unique about this class is we keep the class size small at 10 students because you all will be turning all the wrenches and screwdrivers for the annual checklist.
Because of he way we teach, work on the engine, do an annual on an engine and have all the students do the work this will answer all your Rotax questions and since you are doing all the work you will remember more from this class.
There is no way you can attend this class and not learn things.
Tucson, AZ
520-349-7056
Tucson, AZ
520-349-7056
Hi All,
Tucson, AZ
520-349-7056
Tucson, AZ
520-349-7056
Hello
