Hi
Currently I have my current sensor mounted on the batter lead , I would like to switch to show current supplied by the alternator so it is 0 when engine is not running and positive when alternator is supplying power … my question is where should it be installed … over one of the generator yellow leads going to rectifier (G) or somewhere else ?
Thanks
Hal effect current sensor
Re: Hal effect current sensor
My first thought, the yellow leads from the internal alternator are A/C. Where your Hall effect sensor is now is on a D/C circuit. Will it work for A/C?
____________________________
2006 Sting Sport SLSA - N686N
PPL-ASEL, LSRM-A, iRMT
As JJay stated the yellow wires are unregulated A/C voltage going to the voltage regulator. You want to measure DC current being pulled from the battery to monitor the drain on the system so the sensor is already mounted in the correct place. Not sure why you want to measure the current coming out of the generator, that would be irrelevant as long as it's charging the system. Can you elaborate why?
If you just want to know if the generator is working just add a light off the L terminal. I have a red led idiot light on my panel that turns on as soon as I turn on the master and it goes off when the engine starts. If it ever comes on with the engine running it's no longer charging the system. My AMPS on the Dynon tell me how much or how little juice I'm using.
Sorry missed your responses … took my only 5 months to respond hahaha
I got everything working the way Shawn outlined - I was completely changing my panel ( EFIS and radio from dead TruTrak EFIS to the latest GRT ) and the new EFIS/EMS manual was suggesting different setup- ultimately I did not like it so I went with standard setup.
I also got the idiot light installed - works very well.
- Panel.jpeg (190.19 KiB) Viewed 6453 times
