Hey,
Trying to figure out what is the typical cost of gearbox inspection for 912 ULS.
Thanks
Gearbox inspection cost
Re: Gearbox inspection cost
I send all my gearboxes to Lockwood Aviation in Sebring FL. Kerry is their gearbox guru, does a great job, and turns them around quickly at a reasonable price. The price for just the inspection has been running me about $300 to $400 (about equal to the cost of UPS next day air freight both ways). An inspection usually turns up some required maintenance (seals and Bellville washers typically get replaced), adding a small amount to the bill. Occasionally, whole gearsets need replacement - that can run the bill up to a couple of thousand, so be prepared for that.
Yeah, the gearbox will eventually make its way to Leading Edge Airfoils in WI - very similar to your process, my mechanic will get that over for inspection, except he is about 50 miles away from Leading Edge so he will drop it off so that should be a bit cheaper
My plane is at 620 hours now and I have barely used 100LL so theoretically I could wait till 900 or so hours but I get this weird vibration ( very low frequency - almost like plane is being occasionally slightly punched by some invisible force) when on base/final ( basically idling ) but not on the ground so I presume this is some kind of gearbox/prop load related issue.
I don't see any metal or anything like that in oil filter or the plug but given the above I figured it won't hurt to get it inspected ...
Thanks
Thanks
Just for reference … the total cost of 600 hour gearbox inspection was around $700 at Leading Edge Airfoils.
Everything looked good , the only parts that were replaced were usual wearable stuff like gaskets, washers etc ..
