The totally incompetent folks at Tecnam in Sebring finally sent my brake parts after a weeks delay because they didn't pay FedEx and UPS and their account was locked.
Icing on the cake, they sent ONE disk. See photo. Does anyone know the part number for this (what they sent was totally void of any numbers) so I and possibly get it today from someone else?
Brake Part Number
Brake Part Number
- Brake Disk - small.jpg (230.69 KiB) Viewed 6394 times
Sport Pilot ASEL
Tecnam P92 Eaglet
Tecnam P92 Eaglet
Re: Brake Part Number
This is for a CTSW, that also uses the Marc brakes. I know it looks a little different, and I am not sure if it has the same hole spacing for the pins, but it might be an option. Just for a data point the older original CTSW disc looked like the one you pictured with the calico shaped holes.
https://www.ebay.com/itm/264516585392?h ... SwbY5eEj4E
What was the part number for yours? My Brake Disk Part number from Tecnam is 010102107 and the pads are 010203209. These could very well be the Marc-Ingegno part numbers and if yours and mine are the same, have the same part numbers. Or, since my invoice said "BRAKE PADS - OLD STYLE" I may be looking for the older CTSW brakes.3Dreaming wrote: ↑Tue Jun 08, 2021 7:03 pm This is for a CTSW, that also uses the Marc brakes. I know it looks a little different, and I am not sure if it has the same hole spacing for the pins, but it might be an option. Just for a data point the older original CTSW disc looked like the one you pictured with the calico shaped holes.
Sport Pilot ASEL
Tecnam P92 Eaglet
Tecnam P92 Eaglet
Aaah yes. Dealing with Tecnam.
The day my P92E was converted to experimental was one of the best days of my life.
I’m in the process of replacing the poorly designed Marc brakes with Matco’s.
Not the tecnam approved Matcos with the too-small rotors and ball bearings.
Instead, I ordered the Matcos that are like the ones Zenith builders use.
I’m looking forward to stopping without the chattering.
Type47
INTJ
2006 Tecnam P92 Echo Super
INTJ
Matco brakes are the cat's meow. Their customer service is awesome, parts are VERY, VERY affordable and you can buy the parts direct from Matco online and have them in a few days as they always have stock. The entire brake assembly including the 5" wheel and brake rotor for my SportCruiser is $314 per side. They sell rebuild kits for every brake part they sell. Every LSA should have them installed.
The Flight Design number doesn't match up. I suspect they are part number generated by the aircraft manufacture, and not Marc. I am afraid you would have to do a physical comparison to see if they are the same.JJ Campbell wrote: ↑Tue Jun 08, 2021 7:44 pmWhat was the part number for yours? My Brake Disk Part number from Tecnam is 010102107 and the pads are 010203209. These could very well be the Marc-Ingegno part numbers and if yours and mine are the same, have the same part numbers. Or, since my invoice said "BRAKE PADS - OLD STYLE" I may be looking for the older CTSW brakes.3Dreaming wrote: ↑Tue Jun 08, 2021 7:03 pm This is for a CTSW, that also uses the Marc brakes. I know it looks a little different, and I am not sure if it has the same hole spacing for the pins, but it might be an option. Just for a data point the older original CTSW disc looked like the one you pictured with the calico shaped holes.
Except when you get a little wear on the brake pads and the piston gets cocked in the caliper housing causing the brakes to lock up.ShawnM wrote: ↑Wed Jun 09, 2021 6:31 am Matco brakes are the cat's meow. Their customer service is awesome, parts are VERY, VERY affordable and you can buy the parts direct from Matco online and have them in a few days as they always have stock. The entire brake assembly including the 5" wheel and brake rotor for my SportCruiser is $314 per side. They sell rebuild kits for every brake part they sell. Every LSA should have them installed.
Odd, I've been flying my SportCruiser with Matco brakes for nearly 8 years now and the only problem I've had is a leaky o-ring on the piston inside the caliper. Cost me a whopping $6.85 for a new o-ring and piston. Never had a lock up. Gotta love those Matco brakes.3Dreaming wrote: ↑Wed Jun 09, 2021 8:00 amExcept when you get a little wear on the brake pads and the piston gets cocked in the caliper housing causing the brakes to lock up.ShawnM wrote: ↑Wed Jun 09, 2021 6:31 am Matco brakes are the cat's meow. Their customer service is awesome, parts are VERY, VERY affordable and you can buy the parts direct from Matco online and have them in a few days as they always have stock. The entire brake assembly including the 5" wheel and brake rotor for my SportCruiser is $314 per side. They sell rebuild kits for every brake part they sell. Every LSA should have them installed.
Every couple of years I replace the pads when they reach the wear indicator, $86.
I have heard of it and experienced it myself with the Matco on Flight Design CT's. I also know of it happening on a Lancair. It is rumored to have caused the landing accident of a CT landing at a remote strip. The fall out caused the shutting down of the old CT forum, and the start of the new one quite sometime back. That being said the CT uses a different wheel and brake assembly compared to the Sport Cruiser. I changed disk and pads during a tire change on one of those earlier this year.ShawnM wrote: ↑Wed Jun 09, 2021 5:00 pm
It's obvious that you see more brakes than I do being an A&P so I have no doubt there have been issues. And yes, there are MANY different Matco systems available. My SportCruiser setup is VERY simple and effective. I should count myself lucky then that my only issue with my Matco brakes in 8 years cost me less than $7. I keep that on hand in my sofa cushions.3Dreaming wrote: ↑Wed Jun 09, 2021 5:31 pm I have heard of it and experienced it myself with the Matco on Flight Design CT's. I also know of it happening on a Lancair. It is rumored to have caused the landing accident of a CT landing at a remote strip. The fall out caused the shutting down of the old CT forum, and the start of the new one quite sometime back. That being said the CT uses a different wheel and brake assembly compared to the Sport Cruiser. I changed disk and pads during a tire change on one of those earlier this year.
