Aerovoltz Lithium-Iron batteries
Re: Aerovoltz Lithium-Iron batteries
Postby Warmi » Sat Feb 23, 2019 1:19 pm
https://www.atsb.gov.au/publications/oc ... -2018-124/
Reading reports like the one above makes me wonder if lithium batteries are at the safety point where I would want them onboard. Of course, ultimately it was an operator error but we are all humans and any piece of technology that can backfire so spectacularly doe to a relatively minor error gives me second thoughts.
Postby FastEddieB » Sat Feb 23, 2019 5:50 pm
Thanks for that, and taken into consideration.
A few points...
1) My John Deere regulator, and the Ducati before that, tend to settle in at about 14v, which is approved for Aerovoltz batteries.
2) At the first sign of an over-voltage condition, master switch OFF and land as soon as practicable.
3) A stone-dead lithium-iron battery is toast.
4) Any chemical device storing a lot of energy runs the risk of releasing that energy in a dramatic way. I’ve had two lead-acid batteries explode while being charged. It’s also not pretty.
One such:
But, again, I appreciate the concern. I’m ordering my new battery in about a week. After 5 years of use, my current Aerovoltz has earned retirement - though as I said before, I’m probably going to repurpose it and try to get every last usable electron out of it!
Postby Warmi » Sat Feb 23, 2019 6:03 pm
I was thinking about lithium batteries as well - once I go ELSA ( which I think I will at some point ) - you just get more bang for your buck ( and weight) with them but then I read a report like that and start asking myself , can I trust , not the battery, but myself with that battery :D
Anyway, I am sure you will do fine another 5 years without any problems.
Return to “Ask The Mechanic”
