Rotax vs Tempest Oil Filter
Re: Rotax vs Tempest Oil Filter
drseti wrote: Mon Jul 19, 2021 1:54 pm
Wm.Ince wrote: Mon Jul 19, 2021 11:14 am
It's a no brainer.
Bill, are you saying that folks who go for the cheapest filter have no brains? ;)
Well . . . the better choice can be made without a brain. :mrgreen:
It's a no brainer.
Actually I think it is the other way around. Those with a brain coose the Rotax filter, which also happens to be about $5 dollars less expensive than the Tempest.
Ergo1
Post by Ergo1 »
With the Tempest oil filter I’m seeing at least a 15 degree jump in oil temps. Before installing the Tempest and using the Rotax, my oil temp was @180 and now with the Tempest it’s closer to 200 degrees. Don’t know if it really means anything, except that in my old plane a Cirrus, I used different oil filters and never saw an appreciable change in oil temps. FWIW
