Cessnaa type master switch/Rotax 912
chuckb01
Postby chuckb01 » Tue Dec 12, 2017 5:27 pm
I'm in the process of building a Seastar, also know as the Peturi in Brazil. I am using a Rotax 912ULS 100HP engine. I have the instrument panel almost done and it was an immense amount of work. One of the things I did that I maybe shouldn't have was install a 2 part Cessna Master switch. This is for the master bat relay and the Alt Field. Terminal "C" on the Rotax regulator. It is not wired yet. Can I use this on this engine/ regulator combination with out causing any damage and will it work as it does on other configurations. In other words can I start the engine with terminal "C" disconnected from B+ and then switch it on after the engine is started without causing damage? If it does work, i probably don't need it, but it's there. The avionics buss will have an independent switch. Or maybe i can just use the Alt switch for that?
Re: Cessnaa type master switch/Rotax 912
Postby 3Dreaming » Tue Dec 12, 2017 6:04 pm
I start my CT with only the battery switch on, and then turn on the generator switch. So I think it should work.
chuckb01
Postby chuckb01 » Wed Dec 13, 2017 9:23 am
3Dreaming Thanks for your answer. And you are using a 912 with the factory regulator? Could you make a small simple sketch of the switch location? I assume it is between the "C" terminal on the regulator and the B+ ? I just need to be sure. Thanks again. :)
chuckb01
Postby chuckb01 » Tue Dec 19, 2017 10:40 am
THANKS!
Return to “Ask The Mechanic”
