Tailwheel a pussycat on grass but a wild animal on pavement
azsportpilot
Post by azsportpilot »
I am a Sport Pilot CFI with over 500 hours of tail-wheel time in quite a few different models, but this one is really challenging
I have a new student with a 1999 Kitfox 3 w/ 80hp 912
You could not ask for a more stable, gentle tailwheel plane when on the grass, but paved runways are a different story
The mains track straight and true but as soon as the tailwheel touches down it swerves radically from left to right, as it slows down it gets even worse
I have flown Kitfox’s before but I don’t remember any abnormal handling characteristics
When preflighting, the tailwheel assembly and associated cables & springs all appears normal
Any ideas?
(I chose the "ASK THE MECHANIC" area in this forum as the problem is "mechanical" in nature, moderator please move if it belongs elsewhere)
John Sarra CFI-S
1946 Aeronca Chief
Re: Tailwheel a pussycat on grass but a wild animal on pavem
It could be either the tailwheel set up or main gear alignment. Most tailwheel issues don't lead to steering problems, unless the tailwheel is not aligned with the rudder. The more likely culprit is the change in toe from the level flight position to the three point position. In the 3 point position with someone sitting in the airplane roll the airplane aft 25-30 feet. Now measure the distance between the main gear. Now roll the airplane forward and re-measure. If you get a significant difference between the 2, you have an alignment issue.
The reason you are seeing the difference on grass compared to pavement is because the gear will slide on the grass, but it grips the pavement.
azsportpilot
3Dreaming wrote:It could be either the tailwheel set up or main gear alignment. Most tailwheel issues don't lead to steering problems, unless the tailwheel is not aligned with the rudder. The more likely culprit is the change in toe from the level flight position to the three point position. In the 3 point position with someone sitting in the airplane roll the airplane aft 25-30 feet. Now measure the distance between the main gear. Now roll the airplane forward and re-measure. If you get a significant difference between the 2, you have an alignment issue.
we will check the alignment (toe & Camber) this weekend
whats your opinion on toe?.... piper used to build in a tiny amount of toe-in at the factory
many people today say a bit of toe-out makes the plane more stable on runways, though it accelerates tire wear
not knowing which camp is correct, I'm inclined to shoot for 0 degrees of toe
John Sarra CFI-S
1946 Aeronca Chief
I would look to see where it is first, and then make adjustments from there. Just remember angles change from level to three point.
JimC
Post by JimC »
Have you checked the kingpost angle?
