The new formula changed the wear additive package (increased the levels of anti-wear materials) and the most significant is a change of the base oil used. This is now a custom formula for Rotax and not anything like the motorcycle blend that they started with. It took more than 4 years of testing in Rotax engines. I think it was 8 blends they tested long term in flight school engines back at the factory that all ran up to TBO. They then selected the best one of the batch."
http://www.transair.co.uk/sp+AeroShell- ... s+2675CASE
"Thomas Uhr, General Manager BRP-Powertrain said, “The collaboration of BRP-Rotax with Shell goes back to 2004. Our decision to work with the AeroShell team on the development of the new formulation for AeroShell Oil Sport Plus 4 was based on the benefits the new formulation would provide to our customers. This joint development is supported by 40 years of Rotax aircraft engines, 25 years and more than 50.000 engines produced within the Rotax 912/914 engines with more than 45 million hours of flight."
New Aero Shell Sport Plus 4
Re: New Aero Shell Sport Plus 4
Thanks for the link, Roger. I have two cases on order from oil-store.com (though back ordered 2 weeks).
The picture shown on the oil-store.com web site is a bottle of the old AeroShell Oil Sport Plus 4. The "new" AeroShell Oil Sport Plus 4 comes in a red bottle. Are they selling the new stuff or the old stuff or is there no difference?
Ernie
CFI, LSRM-A
CFI, LSRM-A
I suppose that there is no problem adding (mixing) the new formula to the old to "top off" between oil changes?
Ernie, they'll be selling the new stuff as soon as it comes in (hence the 2 week delay on my order). Yes, they are different. Richard, yes you can mix them, although I would be highly surprised if your engine required any oil between changes.
That's what I was just thinking. I have never had to add a drop between changes, and don't know of anybody who has had to do so on a 912 unless they were leaking oil from somewhere.drseti wrote:I would be highly surprised if your engine required any oil between changes.
I add about a quarter of a quart every 30 hours to keep the dipstick level in the upper end.
This is with consistent burping... and seeing the oil level trend decline very slowly.
The new Aero Shell has been out for a month or two. It has been at my field. It has been in short supply because I think the UK Shell wound down the old production of Aero Shell to clear the stocks going worldwide and has tried to ramp up with the new Aero Shell, but have dropped behind in orders. They are backlogged and trying to play catch up.
Andy,
I'm going to go out on a limb and bet you case you got last week is red.
Andy,
I probably don't HAVE to add oil.
The level is still at least halfway up the dipstick level area after 75 hours.
To the best of my knowledge I believe that I am being thorough and consistent with burping.
Maybe I'm only partially burping??? LOL
Still no harm right?
If oil were overfilled slightly it would just come out the drainhose right?
If you are trying to maintain oil at the top of the range, I can see adding a tiny bit now and then. If my oil is anywhere on the flat of the stick, I go fly. By oil change time it's usually at the midpoint on the flat, so if I were trying to keep it at the top like you do I might add a bit.designrs wrote:I probably don't HAVE to add oil.
In an environment where you are the only one flying the airplane, burping before each flight isn't really necessary. I check the oil for the first flight of the day, and if it's anywhere on the flat I know burping it will only raise the level. So I call it good and fly. Sometimes if the airplane has sat a couple of days or more, the oil level will be just below the flat. Then I burp and re-check to confirm plenty of oil.
When you share the airplane with a partner, or are renting, burping each time to get a true oil level is probably a good practice.
While Rotax says you can go 100 hours between oil changes if using no lead fuel most people in the field change at 50 hours. Personally I wouldn't consider going past 50 hours unless I were flying a 100 hours every 3-4 months.designrs wrote:I probably don't HAVE to add oil.
Andy, while I may not always burp the engine I will pull it through at least 4-5 compressions or more to make sure I don't have hydraulic lock.
My experience is exactly the same.MrMorden wrote:If you are trying to maintain oil at the top of the range, I can see adding a tiny bit now and then. If my oil is anywhere on the flat of the stick, I go fly. By oil change time it's usually at the midpoint on the flat, so if I were trying to keep it at the top like you do I might add a bit.
Running MOGAS.
Think I will do the 50 hour oil change anyway... but yes I do fly a lot of hours!
I burp warm after pushing it in the hangar and related post-flight chores.3Dreaming wrote:Andy, while I may not always burp the engine I will pull it through at least 4-5 compressions or more to make sure I don't have hydraulic lock.
Then when I come in the next day dipstick gives a good read.
Still, I pull the prop through 8 to 12 blades before flight.
The 912ULS2 in my Sky Arrow has always used some oil.
Early on, it was about 1/3 quart every 6 hours or so. Someone opined it was the excessive foaming of the Valvoline I was using, and when I went to Pennzoil, and later to AeroShell, it went down markedly.
Also, burping the engine after each flight and checking it then seems to have helped get consistent readings.
Still, now its maybe 1/3 qt between changes when it gets down to the lower third of the flats - especially before a cross country.
My last oil change was at 27 hours, done early as part of the annual - I definitely need to fly more!
Is my consumption related to my slightly low compressions? Who knows? I also lose a few drops from a tiny untraceable leak but I don't think that could account for my usage.
