Rotax 912 External Alternator
David
Re: Rotax 912 External Alternator
Post by David »
jnmeade wrote:
David wrote:I did have to modify a few things to make it fit.
thanks very much for the very useful pictures.
Is that the oil filter under cylinder # 2? Did you have to modify how you mounted the oil filter?
Hope the pics helped, the only modification was the bracket, which lowered the Alt so it would fit under the cowl. I did have to do some changes to the cooling shroud for the RV12, by moving the scat tube from the passenger side intake instead of the pilot side. This is a RV12 issue only.
Good Luck BTW the guys at Lockwood were very helpful for wiring and installation
