I purchased a Remos GX last year with the aviator II glass panel. I have been having severe voltage drop offs as the plane heats up. Mainly affects the radios. (tansmissions are broken up, particularly at low RPM). Remos is reportedly having this problem with many of the aircraft delivered with the aviator II package. Remos suggested a grounding problem fix but so far this has not helped. Remos support as posted else where on this forum isn't.
Anyone else facing this problem? Have you found a solution.
Remos GX electrical problems
Re: Remos GX electrical problems
We've been through these issues with our G3, AII package like yours. PM me and I can give you my contact info to discuss if you are still looking for help....stanjan wrote:I purchased a Remos GX last year with the aviator II glass panel. I have been having severe voltage drop offs as the plane heats up. Mainly affects the radios. (tansmissions are broken up, particularly at low RPM). Remos is reportedly having this problem with many of the aircraft delivered with the aviator II package. Remos suggested a grounding problem fix but so far this has not helped. Remos support as posted else where on this forum isn't.
Adam
CFI-SP, Light Sport Repairman - Maintenance, Rotax Cert.
Orlando, FL
Orlando, FL
