Jacking a Remos GX
JRamos9920
Jacking a Remos GX
Post by JRamos9920 »
I'm not talking about grand theft here.. How does one go about jacking up a Remos?
John
-John Ramos-
michaelheit
Post by michaelheit »
The pilots operating & maintainence manual is online in PDF format. Here is a link: http://gatewaysportaviation.com/REMOS_G-3-600_POH.pdf you will find information about lifting [not jacking] the aircraft on page 25.
Use caution, and make certain you ahve a second person around to help ...
I hope this helps you.
:P
Mike Heit
