Rotax Enhanced Annual and Service Class Feb. 24 & 25, 2024 or April 1 & 2, 2023
This is a two day class.
Dates: Feb. 24 & 25, 2024 Saturday & Sunday (0800 hrs. – 1700 hrs) Cost: $450
Do to the hands on work a maximum class size is 10-12. Pre-registration is needed because classes are usually full.
Phone: 520-349-7056 or Email: [email protected]
This is an improved service level class that will raise and improve the 100 hour and annual inspection understanding. It will guide people to perform at a higher level of education and knowledge base whether you are a private owner or a mechanic. After discussions and feedback with the students that have taken this enhanced Service class with mostly hands on instruction they feel like they are capable of performing at a higher level with inspections, performing simple service work and documenting in the logbook over some other service classes. This class will have a couple hours of classroom each day, but the majority of each day is all hands on work with a functioning Rotax 912ULS and a 912iS engine and targeting the 100 hour / annual inspection and general service work. We will perform an actual annual inspection on a functional aircraft and every student will be supplied with an inspection checklist. We will demonstrate and perform other service functions. While working you will be able to ask real time questions and take notes to help your understanding of the work when you return home. This will empower owners and mechanics to perform better 100 hour and annual inspections, better DOCUMENTATION, and service-based maintenance on the 912 engines. This class will expand on the already successful Rotax Service class by incorporating more hands on time, but more importantly it will expand on better logbook documentation and will focus on a more detailed and proper inspection process while performing service-level work on the 912 UL, ULS & iS class engine and the 914 engine. This enhanced class will help reduce maintenance induced engine problems and simple time consuming inquiries to the Rotax distributors’ and owners’ maintenance based questions.
Classroom instruction: each day is 3 hours of classroom with engine part props
1. Registering engines
3. Proper use of hose clamps, clamping techniques and the tools. Types of clamps and demo each including Oetiker, Band-It, fuel injection clamps and the constant compression spring clamps.
19. Gearbox removal and installation. We will disassemble a gearbox just to allow students to see its interior parts operation (no maintenance, just prep for shipping to a distributor)
22. Fuel pump replacement
28. Proper prop pitch setup demonstration. This seems to be a big one for many people. Many owners and A&P’s don’t know how to do this and it’s important for the engine.
Ryan Airfield (KRYN)
Tucson, AZ.
LSRM-A , Rotax Instructor & Rotax IRC
Specializing in Light Sport and Rotax Engines
520-349-7056 Cell
Rotax class for 2023.docx
(25.16 KiB) Downloaded 1217 times
Rotax class directions 2023.docx
(12.94 KiB) Downloaded 1215 times
Re: Rotax Enhanced Annual and Service Class Feb. 24 & 25, 2024 or April 1 & 2, 2023
Hi All,
This class is almost full. If you'd like to attend please let me know. I know you'll love the class and be head and shoulders above many on Rotax when done.
Only a few more weeks until the class. We have 1-2 more seats available.
