Happy holidays to my forum buddies
David
Post by David »
David
EAA 1250 KPTW PA
redline
Re: Happy holidays to my forum buddies
Post by redline »
Unfortunately that image won't display because your SSL certificate is invalid :wink:
David
Post by David »
redline wrote: Mon Dec 27, 2021 8:02 pm Unfortunately that image won't display because your SSL certificate is invalid :wink:
Thanks for the heads up, not sure what’s going on. See if works I formated the img command different
See if this works it should need an ssl cert to be viewed
David
EAA 1250 KPTW PA
It was there before the site went down over the holiday.
redline
Post by redline »
This site is secure so it won't display insecure content. You need to add an SSL certificate to your website or serve the image from a secure website/service.
And a Healthy and HappyYear to you also….
