FastEddieB wrote:Merlinspop wrote:Isn't it stated somewhere else, that if an aircraft had an electrical system that it had to have a transponder? Or is that only if equipped with a generator/alternator?
Neither that I know of.
If you can find a source for that, please edify me!
I think this is what I was thinking about (see section D):
§ 99.13 Transponder-on requirements.
(a) Aircraft transponder-on operation. Each person operating an aircraft into or out of the United States into, within, or across an ADIZ designated in subpart B of this part, if that aircraft is equipped with an operable radar beacon transponder, shall operate the transponder, including altitude encoding equipment if installed, and shall reply on the appropriate code or as assigned by ATC.
(b) ATC transponder equipment and use. Effective September 7, 1990, unless otherwise authorized by ATC, no person may operate a civil aircraft into or out of the United States into, within, or across the contiguous U.S. ADIZ designated in subpart B of this part unless that aircraft is equipped with a coded radar beacon transponder.
(c) ATC transponder and altitude reporting equipment and use. Effective December 30, 1990, unless otherwise authorized by ATC, no person may operate a civil aircraft into or out of the United States into, within, or across the contiguous U.S. ADIZ unless that aircraft is equipped with a coded radar beacon transponder and automatic pressure altitude reporting equipment having altitude reporting capability that automatically replies to interrogations by transmitting pressure altitude information in 100-foot increments.
(d) Paragraphs (b) and (c) of this section do not apply to the operation of an aircraft which was not originally certificated with an engine-driven electrical system and which has not subsequently been certified with such a system installed, a balloon, or a glider.
[conjecture] So, I suppose someone could comply with the lighting requirement with a battery powered electrical system and still not have to have a transponder if they want to fly in an ADIZ. [/conjecture]
And it doesn't appear to be a universal requirement for an aircraft with an engine drive electrical system... it reads as if it just pertains to the ADIZ. Maybe...the FARs have lots of gotchas in different places.
