No transponder question
pjcampbell
Post by pjcampbell »
Can someone clarify if you can fly into/out of N07 with a vintage no electrical system aircraft WITHOUT having to telephone the radar facility in advance?
N07 is inside the EWR 30nm Mode C veil. The Class B airspace begins @ 3000 ft at N07. Can you fly in under 3000 ft, or still need to get clearance? I'm thinking because it's in the veil, you need the clearance regardless.
Re: No transponder question
You do not need a clearance to go under the shelf nor do you need a Mode C transponder (Since your airplane was not certified with an electrical system).
